Read Data from Omron CP2E from Mitsubishi RJ71EN71 Ethernet Module with R04CPU
jenas6423
Mar 2020
KL
Hi Guys,
I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function.
Suppose it was using FINS UDP as per written in the manual. But I couldnt get it to work. If anyone have successfully tried it before, please kindly advise.
Configuration
Omron PLC CP2E
192.168.1.50
Port: 9600
PC
192.168.1.150
R04CPU
192.168.0.43
RJ71EN71
Port 1: 192.168.1.44
Port 2: 192.168.2.45
Source:
DM0-DM100
Destination
D0-D100
Hi Jenas
I don't know Omron PLC. Do you have an error message on then RJ71EN71 that helps?
It could be the host port you are using. Have you ever tried another one?
The Firmware of the module must be at least v35 to support this communication with Omron. v35 is quite old. I don't think that's the problem
I wish you much success.
If you have more information, you can post it.
Dave
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
124
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
161
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
467
Hello, I want to send the data from Rslogix500 to Excel. I created a connection between RSlinx and Excel. The values in Excel automatically...
1,216
Dear colleagues, I am reaching out for assistance with an issue I am having. I have a code that can successfully insert data from FactoryTalk...
1,099
