Supporting older verisons of Wonderware
Snap25
Dec 2014
Michigan
237
Since Wonderware only allows you to have a single version installed on your machine, what's your method to support older version runtime applications without upgrading the existing version.
if a customers calls with a simple task like adding a push button or a new alarm to the HMI, I don't want to spend the time to upgrade runtime client to my development version.
Dedicated laptops? VM? Download development on each Panel PC and transfer my development license over during the modification?
From what I gather from reading posts here VMware appears to be one of the most popular options, also makes moving to a newer machine relatively painless. I personally don't use them because I have no need.
I personally have 27 different VM's. But I have to have WW from 4.2 all the way up to the latest. I even have a Windows 3.11 machine for one customer who wants a change about once every 2 years on an old Nematron that refuses to die.
I have a project where i have two rx3i plc systems seperated by fiber with fiber\ethernet media converters. Both processors are IC695CPE305. My...
1,142
Just out of curiosity, how long does it take for a lifetime membership to kick in after submitting? I assumed it would be automated but it's been...
2,873
Over the last couple of days I have had the misfortune to struggle to install some XXYZXZZ software. I read that this software will run in...
3,740
<P>please suggest a cheapest siemens/schneider plc that supports ascii communication with third party controllers using rs232 port and also has...
1,940
Hi, I have a project in which I need to communicate with FMC Sybertrol flow computer in modbus RTU. The flow computer has a whole range of...
2,718
