Ifix , i can help
Good afternoon, I need a lot of help from you.
Picture above represents my supervisor, top menu 01 without monitor 01, top menu 02 without monitor 02.
You can also write the script of each button to call your screens due.
Problem and the following, using ReplacePublic, it opens the screens randomly, it opens opens the monitor and does not open the second click and monitors 02 and so on.
Example:
Click here in the top menu 01 on the screen T_102_01 it will open a screen on the monitor 01 ok, now click again on the top menu 01 on the screen T_102_02 it will open a screen on monitor 02, now it can click on the top menu 02 on screen T_102_03 it will open this on monitor 01. How to open a monitor 01 01, click on my upper 02 open the screens on monitor 02. There is only one process screen.
Now its I use the OpenPictures click on menu superiror 01 on the screen T_102_01 it will open no monitor 01 ok if I click on the top menu 02 screen T_102_02 it will always open on monitor 01 if I put on the top menu 02 the scale 0.100 it opens in monitor 02 but closes the screen that is in monitor 01 for one and another that always leaving a password on all screens opened with the parameter OpenPictures, this will arrive in time that will lock me the supervisor.
Does anyone have a solution to help me ????
Follows my doubts link
http://www.plctalk.net/qanda/showthr...light=ifix+4.5
Ifix 4.0 GE Fanuc
I need to open a project.fbk of an ifix 4.0 application on another workstation. What do I need to do to open and view the project?
:desejar:
Gabriel, please keep it to English. It is easier for us to help you that way, it also makes it easier for other people having similar issues to find this thread.
This is a Google translation:
Image above represents my supervisor, top menu 01 without monitor 01, top menu 02 without monitor 02.
You can also script each button to call its appropriate screens.
Problem and the following, using ReplacePublic, it opens the screens randomly, the same opens the monitor and does not open the second click and monitors 02 and so on.
Example:
Click here on the top menu 01 on screen T_102_01 it will open a screen on monitor 01 ok, now click again on the top menu 01 on screen T_102_02 it will open a screen on monitor 02, now you can click on the top menu 02 on screen T_102_03 it this will open on monitor 01. How to open a monitor 01 01, click on my superior 02 open the screens on monitor 02. There is only one process screen.
Now if I use OpenPictures I click on the top menu 01 on screen T_102_01 it will open on monitor 01 ok, if I click on the top menu 02 screen T_102_02 it will always open on monitor 01, if I put it on the top menu 02 at scale 0.100 it it opens on monitor 02 but closes the screen that is on monitor 01 for the same one and another that is always leaving a password on all screens opened with the OpenPictures parameter, with this it will arrive in time that will lock the supervisor.
Hi! I am using ifix first time and looking backup scada to learn things. For Datalink I am using following tag reference and it is working fine...
2,399
Hello, I am working with a system previously developed on a logix500 based slc controller, a new rendition has been made using a compactlogix...
2,304
Hi all,, Can anyone help me in installing the scada ifix software... I have 5 sets of CDs.. is there any one by one methodology in installing...
2,569
I have generated a CSV import file for my database but whenever I try to import, the DB editor just crashes. Is there a way to troubleshoot what...
3,535
Hello. Urge you to help you tell me the code VBA in Ifix 3.5. Specifically, like this: I want to update the operating time of equipment, every 24...
3,925
