IFIX SCADA Datalink Tagging Help
obi1987
Jan 2014
lahore
114
Hi!
I am using ifix first time and looking backup scada to learn things.
For Datalink I am using following tag reference and it is working fine.
Fix32.FIX.TEST.F_CV
But the Scada which is developed by someone else using syntax as below
@Node@PIT01_DATA.F_CV
How I can use it my syntax as above one.Is there is setting to do it or have to define node before using @[email protected] have tried
@[email protected]_CV
Not working in my case.Need Help
What is your SCADA server called?
The @ signs indicate that there is a tag substitution. Try finding a file with extension .TGD and the node variable should be defined there.
Yes you are right, it is tag substitution but where i can define or find it.
.TGD i found them in pic folder but there are so many and nothing like variable definition.
Problem Problem!!!
Creating Tag Group Editor
Symbol:Node
Substitution:Fix32.FIX.AB19_
Actual Tag is Fix32.FIX.AB19_TIT_03
I am using @Node@TIT_03.F_CV
File Tag resolving select pic and than TGD file.Operation successful but is not getting resolved at run time.
Problem Problem!!!
Symbol:Node
Anyone have idea why it is not resolving???
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
443
I have a client that has iFix 5.8 installed with a Primary and secondary node. They have two terminal servers that they use for their thin...
2,212
Hi guys. I'm trying to make visualisation in iFIX5.1 to my project where I use S7-1200 with TIA Portal. I am using PLCSIM with Nettoplcsim to make...
3,063
So, I'm very new to PLC and HMI's and I was asked to investigate something that occurred with my client's system: They set up a queue list of...
1,555
I am new to ifix, I am having an issue, I am unable to receive any information, after attempting to fix the fact that the view was only pulling...
25
5,623
