Communication Siemens S7 1200 <-> Robot over EtherNet/IP
Petr_Broza
May 2015
Vancouver
41
Hello,
I'm trying to figure out, if it's possible to communicate with 3rd party device (robot) over EtherNet/IP. We're trying to prove, that device can communicate over EtherNet/IP, but with Siemens PLC. Also I can not use Open User Communication (TCON communication), but have to use CIP protocol (I'm not sure, if I'm saying it right).
Thanks for ideas
S7 1200, TIA V15.1, UR E-series robot
Why Ethernet/IP? I believe Universal supports Profinet which is native to the S7. Unless you're interfacing with other EIP devices that's the route I would go.
Thanks guys. I know UR supports Profinet, but we're trying to prove, that it's also works over EtherNet/IP. I'm just not sure, if it's possible without any gateway..
Siemens PLCs don't support EIP, although some of the drives/HMIs/etc do. Just like AB PLCs don't support Profinet.
You'll need a gateway if you want it to work.
Just for correctness sake, you can actually connect a Siemens S7-1200 or S7-1500 to Ethernet/IP.
edit: Wrong. You can connect a Siemens S7-1200 or S7-1500 to a ControlLogix and exchange data, but it wont be Ethernet/IP.
There are even library blocks for this purpose:
https://support.industry.siemens.co...ol-system-(clx-glx-controller)?dti=0&lc=en-US
(thanks to JRW in this thread: http://plctalk.net/qanda/showthread.php?t=118178).
But before you get your hopes up, I believe the TIA library blocks are for "messaging" not for cyclical I/O. So if the robot can communicate by Ethernet/IP messaging then it could be possible, otherwise not.
edit: After studying it a little bit, I can see that on the ControlLogix side open "socket" communication is used. This is not the same as messaging over Ethernet/IP. So forget what I wrote above. I believe it is NOT possible to connect a Siemens S7-1200 to an Ethernet/IP device.
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,862
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
213
Developing Communication between Energy Meter(Indigo+ Schlumberger) & SIEMENS S7-1200 Hi Members, I am Currently facing a challenge regarding...
1,489
Hi, I would like to add a new S7-1200 PLC to a network. Wizcon is the SCADA system and already communicating with quite a few PLC types using...
1,748
Hello In attempt to further my education I am attempting to communicate with several slaves reading and writing. I can communicate but there is...
9,003
