You can't go online and monitor the operation of the HMI like you can with the PLC, but you can run the Quick Panel target in simulation on the PC running Proficy Machine Edition. If you enable I/O when running in simulation it will be as if there is a duplicate, independent HMI. That's assuming Ethernet communications with the PLC.
