Modicon Plc Switch To Run Mode
TOMC
Apr 2002
Niagara Falls
58
I have a Modicon compact plc. I downloaded my program no problem but when I try to go into run mode I get a stopcode error 4000(hex).
Any ideas?
If you are using Modsoft to program, hit escape to quit the PLC status screen, and go to the PLC and I/O status under utility menu and hit ALT {h} this will bring up the plc stop codes.
A Modicon Stop Error Code of 4000 is indicative of a "Bad I/O traffic cop table". Check your traffic cop (I/O map is the same thing).
Thanks for your help. It helped out a great deal. I got in touch with Schneider and they said I needed a loadable of an analog card I am using. Up and running hopfully I can make the customer happy now. :)
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
261
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
339
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
401
We've got this old Modicon PLC on a Mobile Skid that has developed "Comm" errors that cannot be cleared (tried moving cables, connectors etc.)...
1,091
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,618
