Does Me/Panelview support a 7 segment font? I have a customer that want's a temperature controller mimic'd on the HMI and it's a standard Honeywell style with 7 segment display.
If the Panelview lets you download True Type Fonts or Web Open Type, then you can do something similar as I had done in an example for AdvancedHMI with a free font:
Ok thanks....For some reason in reading the help, it seemed I was limited to Rockwell fonts....I downloaded a 7 segment TType font and its working on the PC....Won't know for a month or so when I dump it into the PV Plus 1500 if it will work there.
You have to load the TrueType font into the PanelView Plus terminal separately from the project file. There's a seldom-used tab in the Transfer Utility for downloading fonts. It's not automatically bundled in with the *.MER file.
There may technically be licensing issues with TTF fonts included with desktop operating systems being run on a Windows CE box, but in general I've found I can copy the TTF files from Windows XP or Windows 7.
