Omron Fins Commands NT Screen Disk Number
rory
Nov 2005
NELSON
29
I would like to connect a USB Stick to the USB port on a NT screen joined to a CJ1M, I need to know the disk number to address the port, it is connected to the PLC using NT Link. Ie the memory card is 8000, the EM area is 8001, there is a number for each of the serial ports. The other options are a serial port male to usb female, or a decent flash card extension cable say 2m long. The hardware and comms configuration for a flash card do not lend them selfs to long lengths so this would not seem sensible. I would like to know how to write to the USB port on the screen. I am tring to get away from the momory card on the CPU as I don't wan't the operators to open the control panel. There is a bluetooth option but this relies to heavily on opertors and will result in countless phone calls between my self and the operators.
Thanks, what about the port number for the memeory card on the screen and do if via a fins command. Does anyone know the port number for the memory card slot on a NS screen.
Hello, someone have an example of an comunication between an Omron CJ2M CPU33 with FINS TCP to PC? Thanks for help
1,375
Hello people Has anyone managed to perform an arduino communication with an omron PLC through the FINS TCP/IP protocol? I already managed to do...
2,158
Hello Someone know an Function Block or example code for Fins TCP/IP or UDP working for CJ2M CPU33? Thanks for help
1,217
Hi Guys, a few years ago I started to write a little test program for PC to communicate with OMRON PLCs by FINS commands. Well, I would swear...
2,788
hello everybody i want to download fins gateway v3 but i didn't know ... i searched in several website but i didn't get any information ...
1,838
