Arduino + ethernet shield + omron fins tcp/ip
vmlourenco
Dec 2020
Rio Claro, SP
Hello people
Has anyone managed to perform an arduino communication with an omron PLC through the FINS TCP/IP protocol? I already managed to do it via modbus TCP/IP, but I'm trying to do it on a PLC through FINS TCP at the moment
Thank you for your help
https://www.myomron.com/downloads/1.Manuals/PLCs/UNITS%20CS_C200/W430-E-1-01+CS1D-ETN21D+Operation_Manual.pdf
The above manual will explain the protocol. Calculation of the FCS (Frame checksum) is the only tricky part. This is the same calculation as the host link.
This link will show you an Omron FCS calculator from Mr.PLC
https://forums.mrplc.com/index.php?/files/file/174-fcs-frame-checksum-calculator/
https://accautomation.ca/implementing-the-omron-host-link-protocol-vb-net/
I hope this helps you out.
Regards,
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
119
I am working on a project that had originally started on a sparkfun redboard artemis. Through some testing I've pushed to utilize a PLC for the...
1,597
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,759
https://www.arduino.cc/pro/software-plc-ide Diving in when I get home. With its full IEC language support, object-oriented programming...
65
19,716
https://www.hackster.io/news/arduino-unveils-the-opta-its-first-micro-plc-for-the-industrial-internet-of-things-d97f1d6b868a...
32
10,151
