OMRON FINS TCP documentation
HZsolt001
May 2020
Hungary
Hi Guys,
a few years ago I started to write a little test program for PC to communicate with OMRON PLCs by FINS commands. Well, I would swear there was a really nice documentation about this, but I cannot find it. Maybe it was this: https://www.support-omron.fr/telech...Z909-E1-01 CS_CJ EIP21 Ethernet IP Units .pdf
I think Section 7 is what I need. But - as you can see - this document should be at least 163 pages long, but it is only 77 pages. (????) So there is no Section 7 in it.
Does anyone has this documentation? Or any DETAILED information about FINS/TCP FINS/UDP? (I find this page: https://flat2010.github.io/2020/02/23/Omron-Fins协议/#comments but there some really important information is still missing here)
Well, meanwhile I found what I needed. It was the OMRON W421-E1-03 Ethernet Communication of Applications Operation Manual.
(The most important thing what I was looking for is at pages 186 - 191. There is a small C program example for FINS/TCP communication. Using this, I could finish my test program.)
Hello, someone have an example of an comunication between an Omron CJ2M CPU33 with FINS TCP to PC? Thanks for help
1,378
Hello people Has anyone managed to perform an arduino communication with an omron PLC through the FINS TCP/IP protocol? I already managed to do...
2,159
Hello Someone know an Function Block or example code for Fins TCP/IP or UDP working for CJ2M CPU33? Thanks for help
1,219
Hello. I'm trying to communicate between two PLC's using FINS function block _CPU011:ReceiveData. PLC1: IP 192.168.1.50 (MASTER) PLC2:IP...
1,661
Hi, I am writing Omron FINS TCP/IP. I am some bug at my vb program side. I need help. Did someone have the Omron FINS TCP/IP sample program ...
6,581
