OT: In-house maintenance laptop file synch with server
wildswing
May 2005
Sault Ste Marie, Ontario
281
Hey fellas,
My IT guys not at work today so I figured I'd ask here. I've got a couple of maintenance laptops that the guys use to talk to drives and a couple of oddball PLCs not on a network. We have always struggled with keeping up-to-date files on the laptop hard drives so the guys would be working with the latest and greatest versions.
I finally have a couple of nice new laptops for them to use and want to go that extra step and save all the latest & greatest files on our server and both laptops. Won't be like that for long though once the guys start working with them. Traditionaly I would manually check file dates and set them back up, copying the newest to where ever it needed to be.
Both laptops have wireless capabilities and I can log on to our network using a global maintenance username. What I'd like to do is set up a synchronization task or routine that would check to make sure the laptop is up to date or vice versa. Maybe have the guys log on in the shop to do the synch before going out into the field where the wireless network can't reach. Or maybe do it when they get back or both.
Any suggestions on how to accomplish this file synchronization? Windows or 3rd party? FYI...we'd be looking to synch files from a variety of locations, not simply to/from one folder.
if you have access to the network I've had good luck just keeping a acessable drive that is used to store all files for maint/automation.
Out maint department bought into it with no problem after a bit of training.
Just a suggestiong. Keep in mind you need to have access to the network at the location of the machine.
Thanks for the link averytc
Chris S said:
I've had good luck just keeping a acessable drive that is used to store all files for maint/automation...you need to have access to the network at the location of the machine.
Unfortunately that's not the case. Our signal drops to nothing inside the MCC rooms where our drives are mounted, so the guys have to save their work on the laptops local HD.
It's getting that file to the server and the other laptop that I'm trying to make as easy as possible.
We are currently in the process of setting up Version Control Software. Where the maint. guys will "book out" the latest version of the software then go out into the field do what they need to and then book it back in. When they book it in they will asked to provided comments on what has changed. From what I understand the version control software is also capable of regularly comparing plc programs between what is in the plc and what it has in its repository. It's not operational yet so I cant tell you much more. Search for MDT Version Control
GitHub Link: https://github.com/Automation-Standard/Open-Industry-Project This is a little side project I've been working on that I felt would be...
3,470
Hello: I am confused about the A510 modbus addressing scheme. According to Teco's communication addendum the modbuss register addresses start at...
1,709
What is the best way to get warehouse temperatures back to the PLC? The problem is that these are spread out pretty far from each other. My...
2,238
HI: Our goverment has declare legal to cultivate cannabis for medical purposes, a new customer is asking for a quotation where a small PLC...
4,657
So went to check out a pump house job the other day that feeds roughly 150 residences. There is a storage pit/tank that holds water from 4...
30
8,130
