Pump House Controls - Line Pressure PI(D?)
The P2K can do Modbus even better than the 1400 and doesn't need the breakout board for RS485. I have one doing MRX/MRW to Yaskawa VFDs and it is nice. One twisted pair and some relatively easy keyboard magic gets you all the data both ways. I did have a serial port failure on that system and had to replace the CPU, but the RS485 wire was buried 700' to the pump house and took a lightning hit. I installed a comm port isolator along with the new CPU, but for local wiring, you may not need that extra precaution.
The wiring here is pretty much local. Given that I have to install a GSM modem in this system, I figure I might as well do everything via ethernet. Modbus is just fine, but I'm going to use drives that get stocked locally in our only supply house. That means Eaton GS1 series drives. Honestly, I've heard some good stuff about them. I am thinking that if a click can survive that long in there, a p2k should be fine. Plus with P2k there are a LOT more options as far as IO and communications.
89
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
141
Hey Guys, I was looking for a little help on a school project. I was asked to program three pumps with two inputs, more and less. The project...
23
2,529
My department has been tasked with writing the program for a 4 pump lift station that alternates all four pumps (one lead, one lag, two on...
1,081
So I very much new to doing ladder coding I have a pump with a Stop float switch that stops the pump when a sump is low. I want my manual run mode...
1,393
