GE RX3i Rate of Change logic
NetNathan
Nov 2011
Corona, CA
2,199
Does GE RX3i have a "Rate of Change" FBD or?
I need to alarm on an analog signal that changes to fast or "Spikes".
There's no native rate of change function block or instruction that i'm aware of. Maybe some creative use of relational function blocks like compare, greater or equal, less or equal coupled with a timer?
edit: also maybe something worth scripting
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
419
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
311
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
137
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
1,001
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
416
