Proficy iFIX V3.5 VBA code (multiple picture instances)
besogon
Jul 2016
Moscow
Hi. I have a Proficy iFIX V5.8 & V5.5 & V3.5.
In the iFIX WorkSpace V5.5, V5.8 can open multiple instances of a single picture: OpenPicture & ReplacePicture subroutine syntax have part bNewInstance.
How to open multiple instances of a single picture in iFIX V3.5 (by means of VBA code)? Any ideas?:confused:
I have an HMI based on Proficy Ifix 5.5 which contains a header, footer, and main screen. the footer contains a panel of navigating buttons which...
1,361
I am trying to simply display a PLC string tag value (text) in a VBA control (msgbox or anything...just to get it working). The following code is...
5,978
I have a Proficy iFIX 5.8 application running on a Win 7 Embedded OS with a touch screen. I am looking for a way to perform a controlled shutdown...
2,820
Regarding Proficy iFIX 5.8...is there a way to access the properties of an object that is located on Picture "A" from the VBA code on Picture...
6,369
Hi I want to press a button on the HMI screen and write to a bit within an Integer within a control logix PLC. The iFix version is 5.5 and using...
2,396
