andrewjsimpson1
Hi
I want to press a button on the HMI screen and write to a bit within an Integer within a control logix PLC. The iFix version is 5.5 and using the IGS driver to communicate to a compact logix plc.
What i have done so far.
1) Placed a button on the screen with following script.
"closedig COOK1:TESTINT6.f_03"
where COOK1 refers to the database and TESTINT the Integer Tag
I have also configured another button with
"opendig COOK1:TESTINT6.f_03"
2) Configured a tag in the Database
"TESTINT6" pointing to I/O address "JET.Device1.TESTINT[6]
The Enable outputs property is enabled for the tag.
The result is that all 16 bits of the integer go to 1 with the first button and 0 with the second button. Please advise where im going wrong.
The concept is that i want to write to an individual bit in this case bit 3. Once i can prove a system a schema I will use a common picture with simiilar butttons in conjunction with the Tag Group editor to write to similiar objects within my project. ie valve commands.
polite thanks in advance
Andrew
Andrew
