Hi yas,
Pretty new at this...
Looking for some advice on how to get string data in Red Lion HMI via Modbus.
I am bringing ascii data into the redlion via modbus using an integer array.
On the red lion side there is a function called "datatotext" which says its supposed to covert an array to text.
So far im only able to get the first data point to convert...
from description:
data int The first element in an array.
limit int The number of characters to process
string = DataToText(Data[0], 8)
Based on their example shown above, the string should equal the first 8 elements in the data array.
when using this in a program im only getting the value of the first element (0).
Any help would be appreciated.
thanks much
from description:
thanks much
