Sharing Tags between C# app and CitectScada via unmanaged C++ DLL
abdessamedd
Jan 2019
Algeria
I want to make an application in C# .Net to read Tags from CitectScada (Local variables, Variables tags, Digital Alarms ...) so that I can process the data in the C# app. So far I am seeing the best solution to achieve it is to communicate between both with DLL C++ file. I wonder if that will effect the performance of CitectScada if I am dealing with many tags (say 200). I would greatly appreciate it if you kindly give me some better solutions.
I have a Plant that producing a material that another plant about 300 yards away uses .I would like to keep track of the material that is...
3,365
Usually my projects with multiple HMI's have the HMI's displaying different controls for the section of the machine it's mounted to. I have to...
3,649
Something I've never thought about before... maybe you folks have some thoughts or experience. I have a customer that uses a Weidmuller, Modbus...
30
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
175
Hi, We don't do many Rockwell projects but recently did onw with a Control Logix and Panelview. What files do customers expect when you send...
268
