plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 12th, 2019, 07:08 AM   #1
PeeLC
United States
PeeLC is offline
PeeLC's Avatar
Tech Device to tap and record Ethernet/IP connections?
Hello PLCS.net!
I was wondering if there is such a thing available that connects inline with two RJ45 jacks and lets me know what communication is happening?
From what I understand, I don't necessarily want the packet information, but rather the information about the contents of the packet, so the application data.
We are in the AB environment, and would like something to help us log communication between the OPC and the PLC.
Thanks!
-PeeLC.
Old January 12th, 2019, 07:33 AM   #2
Archie
United States
Archie is offline
A SharkTap and Wireshark software:
https://www.amazon.com/midBit-Techno.../dp/B00DY77HHK
It is basically a 3 port switch with a mirrored port that let's you see the traffic. Wireshark does a good job at breaking down the packet.
__________________
Expectations lead to disappointment. Appreciation leads to satisfaction.
AdvancedHMI - HMI Software without the license key hassles
Old January 12th, 2019, 07:33 AM   #3
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Wireshark might be what you are looking for, it's a free download. It installs on any PC on the network.
I records each item on a network that send a packet, and the type of send with the destination IP if it is to a specific other device. It can be filtered to show only data for specific IP addresses, MAC addresses, type of packet or request, etc.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old January 12th, 2019, 07:38 AM   #4
lfe
France
lfe is offline
If the OPC server is running on a PC you can try Wireshark packet analyzer on it.
The hard part will then be to interpret the sequence of bytes since two sources of information have to be used, the first from OVDA about Ethernet/IP and the CIP packets and then from Rockwell Automation about the data contained in those packets..
OVDA documents are not free, you have to be a member and pay a fee to obtain them and as for RA there are a few documents and from my point of view there are incomplete.
__________________
Suppanel HMI
Old January 12th, 2019, 10:49 AM   #5
James Mcquade
United States
James Mcquade is offline
a word of caution about sniffer programs.
one of our guys ran a sniffer program to see what was on the network and brought the traffic to a crawl.
everyone came asking me if I had a network loop.
when we got to him, we had him turn off the program and everything was normal.
please be aware of the network when you run the program.
james
Old January 12th, 2019, 11:08 AM   #6
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
james
Bizarre, I would have liked to be involved in understanding that one. I don't see how Wireshark would do that, it just captures the packets entering the specified network adapter on the machine running it. It doesn't send anything out onto the network. Maybe the program he was running was more than a packet sniffer?
I could see a misconfigured switch used for mirroring or something like that, but it's hard to see Wireshark by itself causing problems.
I have one of those shark taps and have used it many times with no noticeable network impact. To be useful, they need to have no impact on the network or you wouldn't be able to use it for what it's designed for, troubleshooting.
Old January 12th, 2019, 01:19 PM   #7
SD_Scott
United States
SD_Scott is offline
SD_Scott's Avatar
You can run wireshark on the machine that the OPC server is running on. You can set up filters on IP or port number.
Old January 12th, 2019, 01:36 PM   #8
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
To guarantee you are getting all the data on the wire, you would want to use a port mirroring device like a managed switch or the shark tap, running on a different machine than the one the OPC server is running on.
It is possible that the OPC server can intercept inbound packets prior to wireshark being able to see them. RSLinx does this in certain cases, which was what led me to buy the shark tap in the first place. I had to capture the data on a machine that was not running RSLinx.
Old January 12th, 2019, 02:19 PM   #9
SD_Scott
United States
SD_Scott is offline
SD_Scott's Avatar
I think wireshark is ethernet/IP aware. When I wrote my direct driver for the logix platform I used wireshark to inspect the packets. It knew the names of the various areas of the packet like session id, connection id, etc.
Old January 12th, 2019, 03:46 PM   #10
Mark-
United States
Mark- is offline
Quote:
Yes it can dissect some of the traffic, especially the header data. Some packet payloads it does not dissect.
Wireshark, an excellent tool.
__________________
Good luck,
Mark
PeakHMI
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
