Let me start by saying I didn't write this program, I only maintain it.
On power cycle a tag is changing it's value to a number that is not in the program from what I can tell. It only changes one value in the active recipe and then writes it to another device.
I've cross-referenced all destructive bits in the program and the value is no where to be found, only the correct value that it should be writing.
Im certain it's not coming from the device the PLC is talking to because the PLC steps on whatever I manually input into it.
I've been told it may be a default value in the EDS file that it reverts to.
Has anyone had any similar experiences with tag values being overwritten on boot with no obvious source? The SD card is not inserted in the PLC. The HMI doesnt have any Macros and the PLC handles all of the recipes.
Thank you,
MS
Thank you,
MS
