WinCC SCADA TIA Portal v14 - Tab button blinking when there is alarm in screen
DenZ_P
Jun 2016
SomeWhere
64
Hello Experts,
I want to ask how i can make my tab buttons blink when there is an Alarm active in the that screen.
I am just new with WinCC coming from Wonderware, Rockwell SCADA and Ignition background.
Is this possible by script? How do you put multiple tags under Animate Property of a graphic or a button?
Please help! Thanks!
WinCC Advanced or WinCC Professional ?
If WinCC Advanced, then there is no integrated function to achieve that. You would have to monitor all the possible alarms in PLC code, and then use a BOOL or an INT to change the appearance of the button via animation. That would not be difficult though.
If WinCC Professional, then maybe there is. I dont have experience with it.
Even if there is an integrated WinCC function, then I would consider to do it in code anyway, since I bet it will not be simple with the integrated function.
Sorry forgot to mention. It is WinCC Professional.
Hello, I'm a bit uncertain on the WinCC part, now that we have the TIA portal. Before we had Simatic Manager, WinCC Flexible for panels & WinCC...
4,928
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
86
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
81
when i tried to go online, why its showing lie this
88
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
151
