Flexible Lean Manufcturing Cell Wiring Solutions for Clean Room
TConnolly
Apr 2005
Salt Lake City
6,152
We are a lean manufacturing company. We set up assembly cells in our clean rooms where we will configure a line of portable equipment to assemble a product. That line may be reconfigured a few months later to make something else. The flexible lines usually only have small machine tools, many of them are 120V. Often the line is reconfigured by the operators themselves. So we find ourselves in the situation where we have temporary wiring in what would be called a permanent use, with cords running down the line, sometimes on the floor between back to back lines to sources at the wall of the clean room, or stations plugged into power strips that are plugged into extension cords to the clean room wall.
Since its a clean room we can't undertake heavy construction just to reconfigure a cell.
I've been told there are wiring skids for flexible manufacturing cells to solve the code compliance problem, but I can't seem to locate any other information about them. I'd love to find something like movable racks, maybe on wheels, with outlets and/or disconnects and possibly even its own breakers that connect to a single point.
What solutions do you use for similar situations if any?
It's hard to give you complete specs based on the description, but I would definitely recommend looking into "Harting Plugs". They have panel mounted plugs which meet clean/washdown specs and allow you to completely disconnect equipment. The plugs can run ethernet, I/O, power, etc through them. I believe that this would be the biggest challenge for what you're describing. There are also specific panels which you'll have to use; I'm not extremely familiar with those myself, but a local distributor should be able to help.
Dear all, I have communication between wincc flexible rt on PC and cp343-1 i plc rack achieved by direct ethernet cable. Now i nead to connect...
1,914
Hi! can anyone give me some kind of "manual" for "easiest" connecting wincc flexible rt (2008) with s7-300 via cp 343 lean (over ethernet cable...
5,104
hi, please any one tell me how to configure the cpu313c,cp 343-1 lean with wincc flexible-2007 through industrial ethernet to PC or PG. sibi.
2,308
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
315
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
119
