wincc flexible rt + cp 343 lean
apetkov5
Aug 2007
x
101
Hi!
can anyone give me some kind of "manual" for "easiest" connecting wincc flexible rt (2008) with s7-300 via cp 343 lean (over ethernet cable and standard network card in pc with wincc flex)?
computer with wincc flex RT dont have simatic manager installed on it, so I can not import wincc flex project in step 7 manager and make connection...
bets regards
A.P.
In WinCC Flexible, simply specify the connection details to the target PLC with IP adress, rack (always "0" with S7-300) and Slot (always "2" with S7-300).
On the runtime PC, you have to use the Set PG/PC Interface utility to set S7ONLINE=TCP/IP (adapter name).
That is all.
That is all.
well i did it but with no success.
S7ONLINE is set to TCP/IP Auto (adapter name - name of ethernet card), and i can get communication via s7 manager (monitor and download to plc) but wincc flexible dont want to communicate.
Maybe you mean to setup WinCC flexible=TCP/IP ?
Of course, in WinCC Flexible the selected driver must be ethernet and not MPI or DP.
Can you ping the S7-300 CPU from the WinCC Flex RT PC ?
Is the WinCC Flex RT installed on the same PC as STEP7 ?
Exactly what does the error message say when WinCC Flex RT fails to connect ?
Post a screenshot of the connection configuration in WinCC Flex.
ok, i will try it tomorow
yes i can
i have computers without step7 and another for testing with step 7 + wincc flewxible
i will post screenshoot tomorow, but error message "does not say anything special", just like there is no connection
at meantime i got another problem windows 7 32-bit and can not install PG/PC... for this i will create new thread :)
Problem solved.
I reinstall windows from different cd (windows 7, 32 bit too).
Why does not work else... i dont know :(
Dear all, I have communication between wincc flexible rt on PC and cp343-1 i plc rack achieved by direct ethernet cable. Now i nead to connect...
1,913
Hello, I am trying to setup an ethernet link between a computer running WinCC Flexible RT (2005) and a CPU317 via CP 343-1. I believe I have...
4,015
hi, please any one tell me how to configure the cpu313c,cp 343-1 lean with wincc flexible-2007 through industrial ethernet to PC or PG. sibi.
2,306
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
279
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
113
