Maugrim
Hello,
I am trying to setup an ethernet link between a computer running WinCC Flexible RT (2005) and a CPU317 via CP 343-1.
I believe I have everything setup correctly in my Wincc Flexible project. I think the problem is, when I open the Set PG/PC Interface on the host computer (the one with WinCC Flexible RT installed), I can select S7ONLINE (STEP 7), but I do not have a choice to add a TCP/IP interface.
All I have is:
CP5511 (Plug&Play)
CP5512 (Plug&Play)
CP5611 (Plug&Play)
PC Adapter
PC/PPI cable
Is there a separate drive I must install?
Any help would be appreciated.
All I have is:
CP5511 (Plug&Play)
CP5512 (Plug&Play)
CP5611 (Plug&Play)
PC Adapter
PC/PPI cable
