WinCC Flexible HMI MP377 Data logging
tulip
Oct 2005
ist
236
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do not know whether it works because it has not been tested in the field.When a button is pressed, data logging will start, and when the same button is pressed again, data logging will stop.I'm waiting for your opinions.Thanks in advance...
Hello. We tried the data logging event on the customer. We chose Excel as the recording. When we read the USB on the PC, we only see the following headings, but no record values appear under the headings.
VarName TimeString VarValue Validity Time_ms
--------------------------------empty----------------- ----------------------------
Thanks in advance for any support
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,286
Hello, I need to edit the range of values (lower and upper units) set for a unit on my production line with Simatic HMI - WinCC Flexible MP277B...
3,169
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
268
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
109
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,580
