WinCC Flexible, download to MP over Ethernet
userxyz
May 2002
any
2,768
Hi
I'm having an MP270B connected on a Local Ethernet Network, this can be seen as a subnet @ my point of view
IP adresses are 192.168.0.2 and 192.168.0.3.
Is it possible to download from the office ethernet to the MP270 via the PLC that has 2 lean-cards?, I'm connected to 91.0.40.14 Office Lean.
I think not.
Routing from WinCC Flex to a HMI panel must start with MPI. Siemens has told me that they will fix this eventually. There are persons that have posted on this forum that they have succeded in establishing routing that is starting with ethernet (contrary to what Siemens says). I havent been able to do that myself.
You could possibly link your office network with the factory network via a router. Then in the setup of the Siemens S7 CP and the HMI IE you have to specify "use router" and the IP address of the router. This works I know.
hi everyone,,,,, i have a problem,,,,, i have a PLC (CPU 313C V2.6) and the HMI (TP 177B color PN/DP), when i configure in simatic manager V5.4...
19
8,943
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
294
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
116
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
765
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,605
