Good Evening ,
We have a number of Kinetix 6000 Servo drives ( fiber ) that fault out from time to time . I would like to change out the ControlLogix 16 Axis Serco's Module . The one that is in there is firmware 15.32 , but the replacement is firmware 15.37 , and it does not want to talk with ether the drives or the processor. How would I change the firmware on that card ? Also , the processor is ver. 16 . Would I change the firmware on the Serco's module to 16.0 ? With the new Serco's module , According to the plant electrician , the CP indicator is Flashing Red ( Looking for active nodes ) , Ring Status ( O ) Flashing Green ( The Ring , Drive , or Axis are not configured , but at least one has been identified ). The OK indicator is Flashing Green ( The module has passed internal diagnostics , but has not established communication)
Is this something you would ControlFlash for ? If so how would it be done ?
Thanks so much for your help.
