After applying vacuum in mixing vessel Temperature decreased??
jeevan.tp
Sep 2016
bangalore
20
HI,
In a mixing vessel tank, it was maintained with a product temperature of 70 degree.
When vacuum applied to the tank, the product and jacket temperature started decreasing..??? why it happened
Is it under vacuum condition can't we measure the temperature??
Thank you:)
The boiling point of water reduces with atmospheric pressure and will be much less than 70C in anything approaching a vacuum. Your energy is providing latent heat to boil the water.
You're pulling gasses out of the tank. With those gasses goes the thermal energy. Just like when a how a propane or CO2 tank gets cold when you dispense it. If this is a problem, you will just have to pull the vacuum slower, or apply heat to the tank or live with it.
They also do this a lot with food... if you use a vacuum chamber you can freeze or just lower the temperature of the product much faster than at atmospheric pressure, a lot of vegetables need to be lowered to less than 40 deg once picked so they stay fresh
Okay,,let me tell you exactly
Actually with some product and water(extra 30 ltr) added to the mixing vessel later after some time i applied the vacuum to remove the excess of water(30 ltr). In this process the temperature of the mixing product was 70 and jacket temperature was around 75. when we applied vacuum it temperature started decreasing.
My question is how the product temperature reduces?? whether applying vacuum makes the vessel cool ??
I just told you that, man. This is how air conditioners work, by compressing and decompressing gasses in a continual loop. Picture two pressure vessels. You move the gasses back and forth between them, but never outside the system. As you evacuate one vessel, it cools. The other one heats up because it has all it's thermal energy, plus the newly added thermal energy forced into the same area. Higher concentration of thermal energy = higher temperature. After some time, the hot tank will disperse this energy through the wall of the tank and into the air, and the cold tank will absorb.
Do you mean that you have a completely closed environment, and you are reducing the pressure by removing liquid/gas CREATING a semi-vacuum environment?
Or is it an open environment and in this case you mean vacuum like the appliance where you are removing water but air is free to take the place of the liquid you are removing (therefore keeping pressure ~1 atm).
If it's the former, I think the question has already been answered.
Then yes, applying a vacuum to a closed environment by removing matter (which takes heat energy with it when removed) will cool the environment.
+1.
The water evaporates. Boils. Changes from a liquid to a gas. As the molecules expand, they take heat.
Put water on your hand. Blow on it. It's cold, because you increased the rate of evaporation. Same thing is happening inside your vacuum chamber.
Put a cooler before the vacuum pump and you will have a better efficiency
for example sugar is made this way, they boil out the water, by putting energy in and vacuum to reduce the boilingtemperature.
With a cooler you only need a small pump, as it is only used to take out the non condensable gasses.
This really doesn't have anything to do with boiling. You would see the same cooling effect by pulling a vacuum on a vessel that is all gas and no liquid. But yes, liquids are more dense and hold more thermal energy. They evaporate at room temperature in a vacuum an get sucked out as gas, taking that heat with them.
I have a device that is communicating to ControlLogix L83E. During apply of online edits to plc, the communication to the device is increasing 4-7...
1,180
When using AOIs in RSLogix 5000, how can I make changes to certain settings be applied to all instances of the AOI? For example, I create 20...
4,152
I want to study about electrical design as electric box,...But I don't have any documents. Please provide for me some documents, Thanks,
2,318
hi friends, frankly speaking I dont know much about the latest technology regarding plc so if you can help me out with this it will be very good...
5,178
fredfloggle
F
I have an application where I need to push a (car) shifter button to 2 different forces. I have taken a 5 position, 2 way center port blocked...
6,327
