24 VDC to 24 VAC (50Hz)
I don't know what part of Germany you are in my friend, but here's a list of inverter manufacturers. Trouble is, as it's Saturday/Sunday, where are you going to find open?
Maybe look for a good caravan/campervan outlet (motorhome). They tend to stock different types of inverters and are often open on Sundays. Ask at your hotel reception?
Regards
George
Thanks! I will check it out. Know of any web based shops that might carry it? I'm in Nürnberg, staying until Friday so I can wait that long..
Thank you!
I think most common is from DC to higher AC voltages. But if you are in big need maybe a converter to higher voltages is OK and then use a transfomer to get down to 24VAC?
Ooppss! Silly me...forgot the link...
http://energy.sourceguides.com/busi.../invert/byB/manufacturers/manufacturers.shtml
I don't see any in Nürnberg though?
Yeah, most common probably are for the likes of 230VAC output for outlet supply voltage, but I used to do a lot of CCTV when I contracted and 24VDC>24VAC inverters are quite common in that game. Another sector to look into maybe?
I was thinking you had to have something for tomorrow morning in a hurry. If you have a few days, and you can't find a store to walk into, then maybe try online for delivery? I've checked Radionics and Farnell online, but they only stock higher AC output inverters, sorry to say.
I used to use something like this for CCTV...
ABSOPULSE Electronics CSI 50-24/24-FT
G.
This is looking promising. I am sure I can get that over night from Switzerland (if the have it in stock) thank you so much!
UL 508: Any reason I can't supply a 60W 24VDC power supply from 2 legs of 480VAC? Our MechE is asking, it is for a product I don't deal with. My...
5,886
Intern here, I have been tasked with setting up a 24V Keyence vision system. Looking at the control prints, the existing input signals are sinking...
1,819
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,747
The people I work with are not electrical people. I run into this struggle almost every other week on why I choose to use 24VDC. I have some...
45
16,958
Anyone know of a good TOF relay I can use to catch a high speed 24vdc (~100ms) and signal a 120vac input module? This is a pig that goes through...
2,791
