Opening a FactoryTalk 8.0 Project in FT10.0 without updating
jakeparsons03
Jun 2017
Indiana
78
I have a client's project file that is in FactoryTalk 8.0. We are currently running 10.0 and when I open up the project it wants me to convert. The problem is that I am going to build out our system in their backup locally then copy our files to their system while on site so I can't update the software version without it becoming incompatible with their existing running system. Is there anyway to work in an 8.0 environment without doing a complete install of FactoryTalk 8.0?
Your version 10 can create a version 8.0 .mer file (as long as you do not add anything which is not compatible with the earlier version).
Edit: If they are using version 8.0 Studio it will need to have been patched using the Jan 2018 or later patch rollup to open the version 8.0 .mer you create -- see Rockwell Knowledgebase Answer ID 1041447. This will not affect loading or running the .mer in the HMI, just their ability to open and make further changes.
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
107
Hello all, been a while. I am unable to open Transfer Utility as a stand alone or threw FT View Studio. I have reinstalled FT View Studio, Linx...
1,443
Here we are in v12 of FactoryTalk View and from what I can tell, we still don't have a quick and easy way to close a popup after opening a new...
4,162
Hello, I had version 7.00.00 application, saved it as version 6.10.00 and restored in Version 6.1. Out of 8 displays 3 displays are not opening...
2,185
Hi. So I made an alarm banner as a global object in FT ME, this is because this alarm banner goes at the bottom of every display in the project...
6,058
