Panelview Firmware Update
Aug 2017
Wisconsin
25
Having an issue when I do a firmware update and if there is anything saved on the HMI drive it deletes it. Is there a way to backup everything on the HMI drive ( not just the programs )?
Hello littlereiter99, can you just upload using the transfer utility? Or was there something else you were trying to do?
Yes I am looking to completely back up the HMI "C: Drive" in case a machine manufacturer put any pdf files or anything on it that would be lost with a firmware update
Oh, I see. I haven't done that yet myself. I would be curious to learn this myself.
IIRC, on the newer panelviews you can type their IP address into windows explorer just like you would with a PC. Ex: \\192.168.1.1
You can see the file structure and copy any necessary files straight off the hard drive through the network. This definitely doesn't work with all models, but I have done it before on PV+6s I believe...?
Yes I have done that before as well sorry, but the issue is that they had a hidden folder that I could not see on the drive so was just wondering about a complete backup?
Thanks I will attempt this the only issue I possibly see with this is it says it stores the firmware so wont help me if I am still looking to go from v7 to v9 will let you know. Thanks
The only other thing I can think of is to make sure your windows settings are set to "show hidden files/folders", which might reveal the hidden folder so you can copy the PDFs manually.
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
498
Hello, I have several SLC-500 based systems. The user interfaces are PanelView 2711-TC1 touchscreens with firmware revision 3. I purchased a...
2,103
I just updated the firmware on a PanelView Plus 6 via a VPN connection. Prior to the update the FTP and VNC servers had been enabled. Now it...
2,615
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
220
Ive got an existing panelview plus 1000 with a logic module of 2711P-RP and an assembled pn of 2711P-T10C4D1 running out in the field. Its in an...
1,211
