Loading PV 800 with a USB stick
rejoe.koshy
Dec 2011
kolkata
195
Hey Guys,
I had a PV 600 series HMI which has been migrated to the newer PV 800 series. Considering the same I have used .CHA file to convert the application to the new platform using CCW.
Is there any way to load the converted file to PV 800 using USB stick? I am new to PV 800 hence kindly bear with me.
The converter folder contains a file with .ccwsln extension and a folder named PVc project and SpyListPersistence.
In "File Manager" there are "Source" and "To" selection boxes. If you select the USB drive in the "Source" box you should be able to load any valid configuration file that's on the drive. I think you have to have the file in the drives root folder (not in a sub folder) but I don't know that for sure.
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
47
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
154
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
369
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
196
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
126
