Allen Bradley Micro850 - Not Reading Inputs, Not Enabling Outputs?
cschwartzman
Dec 2017
**** Off
Hey folks!
Bumping into the most basic and annoying of problems. My Micro850 isn't reading inputs and it isn't enabling outputs. I used a jumper wire from the +24v power terminal to _IO_EM_DI_00 and, while the power light and the RUN light is lit up, the corresponding input led doesn't turn on.
My program, such as it is, consists of a normally open contact (_IO_EM_DI_00) in series with a single coil (_IO_EM_DO_00), which was built and uploaded to the PLC before testing.
Ideas? Tutorials? Is it possible the PLC is ****ed up? Is there a factory reset option somewhere that I can't see?
Help, please :/
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,352
Hi, Iam Working in a project where Micro850 and Epson ROBOT is there, I need to read and write bits to and from ROBOT. Iam Using TCP/IP and...
1,260
I'm having major issues programming the high speed counter function on the Micro 850. I have no more avenues to pursue... I've tried everything I...
8,535
359
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
92
