TECO SG2 Experience
bullet_head
Aug 2012
Los Angeles
I just started a project with a SG2-12HR-D from Factorymation I got about two years ago and I cannot connect to the darn thing to upload even a test program I made for it with the free software that came with it. I powered it on and the screen is green and blinks and the software cannot communicate via the serial cable. I tried different ports and even a USB to serial adapter with driver from their website but no luck. I thought the blinking screen might be a error code but there is nothing about it in the manual. o_O
Has anyone else had difficulty connecting to any of the SG2 PLR's to program them?
I have used these for home automation, (many years ago) and never had an issue. I would do a little trouble shooting to narrow down the possibilities.
1. Do you know for sure that your cable works?
2. Have you tried a different PC?
3. Have tried entering a simple rung from the SG2 status screen?
It's been awhile, but I think you have to have the cable connected at power up,not sure though, also there may be a programming switch. Have you read the free manual?
The user manual gives a simple procedure for establishing communications with the relay from the SG2 Client software via the serial port. Have you selected the correct port / (the software gives COM1-COM8)
I tried connecting it to two different computers. Also I messed with connecting the serial cable by way of a USB serial adapter so I could use the driver they recommend and selecting the proper COM port with no luck. I checked and there are no pins broken on the connector.
Can I do that without connecting it to a computer? When its powered on the screen only blinks and the buttons have no functions to select from.
Hello all, I am completely new to PLC programming and automation in general. I am working for a company that wants to use a TECO SG2 PLC to...
1,526
This is my first time posting I have sg2 12hrd with a sg22ao module I have never programmed a analog output before and I was wondering if I could...
1,388
Hello - I'm sure this is a total rookie error ...but i've racked my brain and logged off/on, cycled power, substituted my final ladder program...
1,908
Hi, I'm trying to figure out how to use the SG2 modbus slave mode to both set a value in a register as well as set a single coil. It appears...
1,667
I have a TECO SG2 that when a link to the controller all is fine. When I try to read the controller I get "Commands do not match SG2 edit mode"...
3,382
