TECO SG2 Communication Error
RanMan
Oct 2014
Alabama
I have a TECO SG2 that when a link to the controller all is fine. When I try to read the controller I get "Commands do not match SG2 edit mode" and the software will not display the logic. After research, it appears to be a communication error of some sort. Has anyone ever experienced this? How can it be resolved? I am very new to TECO so I am unfamiliar with the correct actions to take. ANY help would be GREAT! ! ! !
I have seen comms errors with the SG2 devices before. So much so, I stopped using them. No matter what I did - switched laptops with serial ports, different USB to serial adapters, PCI card based serial ports, switched cables, changed SG2 devices... I just can't read them reliably. So I punted - I threw away the ones we had and bought a different brand. It's too bad, with such an attractive price I could have used them all over the place.
Thank you for responding . . . We currently have two others running equipment flawlessly that i connected to, read the logic and saved the file. When I got to this one however, it throws this error . . . Its driving me InSaNe! What alternative brand did you choose if I may ask? and price?
I have used several SG2s for small projects and never had any problem with them. Did you contact Factorymation's tech support??
I know people have used them successfully, but I just couldn't anymore. Could be me...
I replaced with some Unitronics devices. Turns out they are a little more money, but the ones I used had the small color HMI built-in, so it was a nice product.
TECO "Commands do not match SG2 edit mode" error
The “Commands do not match SG2 edit mode” means that the proper programming mode has not been selected (FBD/Ladder).
The 5-contact ladder program requires the SG2 have V3.6 and higher firmware.
Next, verify the firmware of the SG2, you can do this by looking at the RTC SET in the SG2 menu.
Hello all, I am completely new to PLC programming and automation in general. I am working for a company that wants to use a TECO SG2 PLC to...
1,522
This is my first time posting I have sg2 12hrd with a sg22ao module I have never programmed a analog output before and I was wondering if I could...
1,384
Hello - I'm sure this is a total rookie error ...but i've racked my brain and logged off/on, cycled power, substituted my final ladder program...
1,903
Hi, I'm trying to figure out how to use the SG2 modbus slave mode to both set a value in a register as well as set a single coil. It appears...
1,666
I have programmed a timer into my sg2. It closes Q1 when it gets a pulse from I2, then as it gets pulses in from I4 it will subtract I2 from I1...
1,611
