timers
cscdummy
Sep 2010
Indiana
Hello all I am sort of a jack of all trades and I need to learn PLC's to further my career at my current job. I know the I/O side of them for troubleshooting but I need to learn to program as well as many other things. So heres my question. Im writing a simple program on RS500 and I wired one input and one output and then programmed those. That worked but then I wanted to add a timer. I moved the timer in between the input and output and got faults. So I moved the output to the next rung and was trying to program a contact related to the timer on the above rung and also faulted. How do I enable an output off of the timer?
Do you want an output to come on when the timer is done?
Post your code and someone can take a look. (zip the .rss file and post.
The SLC500 only allows one Output Device in a Rung. An OTE Output Coil is considered an Output Device, as is a Timer. If you want the Output to turn on when the Timer is finished you want to use the Done Bit. i.e. T4:0/DN, and if you want the Output to turn on during the Timer timing cycle, you want to use the Timer Timing Bit. i.e. T4:0/TT. I suspect you just tried to use the Timer Address with the Bit Address, which will give you an Error.
Download the SLC500 Instruction Reference 1747-RM001G-EN-P.
You can get this at the AB Literature Library, and search for the above Document Number.
http://literature.rockwellautomation.com/idc/groups/public/documents/webassets/browse_category.hcst
As Mickey suggested, you can post your Program as you have problems, and we can help you out with it. (Zip it first)
Stu....
Up the top of this page you will find a link to some tutorials. Check them out! Well written for the amateur.
Might be easier to think of a timer as something that creates an input. You could also use the /acc.x
|-(I:x/x)------(T4:0/dn)---(O:x/x)---|
---------------(T4:0)--
Plcmentor.com has videos on how to use each of the more common instructions and goes into good detail on each. He also has videos on creating files and uploading/downloading. Not sure what cost is now, but I'm sure they're worth it.
There's also this
http://www.engineer-and-technician.com/category/programming/
http://www.kronotech.com/LadderLogic/Basic/timers.htm
http://www.wisc-online.com/objects/viewobject.aspx?id=iau5907
There's lots of stuff out there if you search.
try a google for ( slc 500 site:wisc-online.com )
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
570
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
420
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
148
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
654
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,963
