Faizan_Automata
Hi everyone
I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the output coils or contacts. But, one things seems abnormal to me that FATEK has on delay timers that run when the Enable bit has been given a contact activation so after the timer elapse and the activation of respective coil or contacts, I want to make the timer get stopped as it has already activated the coil so no need to run but it keeps running as the ladder contact enabling it are on active high. So , is there any method to stop it after activation of contact or it should be kept running till the power cut? Also, other PLC timers works in the same way like this or not?
Your suggestions will be highly valuable
