Usage of Timers in Winproladder software for FATEK PLC
Aug 2023
Rawalpindi
Hi everyone
I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the output coils or contacts. But, one things seems abnormal to me that FATEK has on delay timers that run when the Enable bit has been given a contact activation so after the timer elapse and the activation of respective coil or contacts, I want to make the timer get stopped as it has already activated the coil so no need to run but it keeps running as the ladder contact enabling it are on active high. So , is there any method to stop it after activation of contact or it should be kept running till the power cut? Also, other PLC timers works in the same way like this or not?
Your suggestions will be highly valuable
It depends how your logic is arranged; can you post a screenshot of what you are talking about?
"Stopping" the timer usually means resetting the timer, which is done in one of two ways:
  • Make the input to the timer go False
  • Use a RESET instruction on the timer's data object
Thanks and is it OK to not reset it and keep it running even after its usage in the program?
Yes that is okay to leave the timer expired (it is only a bit with its value maintained as 1 instead of as 0) as long as the coil is to stay on; in fact it might be simpler because then the timer output can drive the coil (that is delayed to be a value of 1) directly, and you don't need another "seal-in" or "latch" circuit to maintain the coil.
Dear all, I have some query about the use of Timers in Fatek PLC Module by using WinproLadder Software. I am trying to use one timer instance in...
1,269
I am using quantum PLC and gotta problem with timers. The ET bit which shows the internal clock runs into days and hence the output Q of the timer...
1,720
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
208
Anybody have any experience using a tone generator on analog signal wires? Trying to locate two analog level sensors in an old plc5 panel that...
1,020
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
424
