S7-1200 simulation
PLC Pie Guy
Jun 2013
Halifax
1,144
Hello there.
I am working this morning with an S7-1200.
I am not having any luck getting on the Simulation mode. The "start" tab on the simulation option is greyed out. This means that it is not an option with my particular project for whatever reason I am not sure.
The software is TIA Portal Basic, SP1, Update 4.
Am I crazy? because I was sure I was able to run simulation mode on this software, however I have not tried since installing the SP1 and new updates.
Any insight?
Thanks Mike.
I figured that was the case. I thought I had used it before but I guess not. I guess that's what happens when you are looking at 3 types of PLC in one morning. The kicker is all three are on one very poorly built machine.
Thanks for the reply!
Hello, I’m developing a program and i found that my simulation works very well when i use CPU 1500 but when i use 1200 and i click download. A...
1,936
We are using s7 professional v14 upd2.We open project run simulation prog.plc prog.is running test mode,we see.Hmi prog.is running (because we...
2,241
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
254
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
