Panelview Plus 7 - Can you play live video from a camera ?
Rob S.
Sep 2008
Maryland
739
Good Evening ,
We have a machine I'm going to be doing an upgrade to. I would like to use the Panelview Plus 7 - Performance . We have some blind spots on this machine , and I would like to place some cameras on the machine . I would like to place command buttons on a screen that will make these cameras visible. Is there something like " Hyperlinks" that work that would allow live video to be shown from a camera ? If not , do you have any suggestions ?
Thanks so much for your advice ,
I don't know if the PanelView Plus 7 can show the "NTSC or PAL" video format!
But I do know that several of the Maple System Hmi do have this capability and would do exactly what you seek.
They offer 2 video inputs that would take the camera feed directly and show on a screen, so you could have a button that says camera 1 and another for camera 2 which would show their LIVE feed.
Now should you ever need more than 2 camera's just add a (Example) 4 channel video multiplexer with adjustable dwell time and now a single input will rotate thru all 4 camera's.
Just a thought???
First time using a panelview. I have all of my alarms mapped to bits of dints. How do I get the alarm panel to popup when an alarm happens...
2,144
Hi, i am new to this forum and almost new to automation world. I want to display a list on HMI which should be updated as it gets data from PLC...
981
22
4,756
Greetings. I have a project in PanelView Plus 1000, that cosist in datalogging some variables using the ActiveX object DataStorePlus. For that...
1,461
I use PanelView Plus 7 Graphic Terminals Model: 2711P-T10C22D8S-B PLC: Compact Logic 1769-L36ERM Tag ER[4].8 -> ON, the message is "1046 Abnormal...
1,782
