TheWaterboy
I expect I know the answer for this - but if I buy the Cisco switch vs the stratix switch - will the AB AoP work for the Cisco switch too (ie2000 for example) or has that ability been completely disabled in the Cisco versions?
I ask because I need to put the network status and traffic flows on the Scada system instead of using its own management software. The FT network management software, and Cisco's too, is quite expensive. The AOP gives me enough metrics to make a reasonable map.
I don't use FT View (yet? ) so I cant use the faceplates, just the AoP.
