WinCC + Clients-What is required from Siemens
Greg Fowlds
Apr 2004
Currently, Waiheke Island, NZ
123
Have a project that customer requires WinCC V7.0 (Not Flex)
1 x Server.
3 x Clients.
Less than 2000 tags to/from PLC, Less than 512 Tags for trends.
Am getting lost with what to order, have never used WinCC before or even seen it running anywhere.
A RC2048 (6AV6381-2BP07-0AX0) has Run Time + Configuration.
Is this classed as a server?
Would this run as an operator station as well or only as server?
A RT128 (6AV6381-2CA07-0AX0) as a client.
Will the RC2048 configuration handle the client as well as server or do I have to purchase a configuration for Client and a different one for server.
Running Siemens online order system there is no heading for server only.
Edit: Found some more information on Siemens site.
Does this sound correct
1x WinCC/Server
1x RC2048
3x RT128
Yes you are right.
For the server: You need WINCC RC 2048 tags on the server + wincc server add on
For each client: You only need the basic WINCC RT128 for each client
512 Archive tags for trends is included in the basic license for RT / RC.
Just take a look at the compatibility list so you know what you need from the PC side.
As you can see, the server station can't run in Windows 7 SP1 for example.
Yes you are right.
Dear rohan tandon
If we exceed the number of 128 Tags then what will happen in RT Client PC..??
Thanks.
I am working on a project where I need to create a visualization screen (HMI Panel or PC) using wincc tia portal v16. It will be connected to the...
541
Hi, Is it possible to connect WinCC 7.0 Clients to Wincc 6.2 Server?
2,500
I am doing a test with wincc v6 I configure a wincc server and try to have some client you know when create a wincc project it will be generated...
4,452
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
65
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
