Off Topic - High Voltage Power Line 500 kV Circuit Switcher Testing
Very cool video!!!! Can I have one of those for my Halloween party next year? I'd be the envey of the county!!!!( And I'll bet the folks watching TV in the surronding 5 counties, too!!!!)
BTW, what was the cause of the single phase arcing ?
David
beerchug
Not sure, in the video, there's a arc across the first insulator, just before the "Switch" opened.
Maybe it was enough to start the arc to cascade across the "Switch contacts"
From the video sound, it must of been REALLY loud for the people at the site.
Also, I might think that they could feel the heat coming off of it, even at a distance.
I found somemore info about the HUGE ARC at this website:www.teslamania.com The explanation says that the utility was conducting a test to isolate the problem. A SF6 gas puffer interupter flashes over one of the phases allowing the air break switch to open hot. The switch wasn't under load and ONLY carrying ~ 20 to 25 amps of line charging current at 500kV!!! The arc shuts off when an oil circuit breaker upstream is commanded to open. Take a look at the other video on the site of a substation failing under load. He also does some pretty cool things with a very large EMP to coins.
Hi all! I have a 400 watt metal halide high bay light fixture that will light, stay on for a minute or two and then go out. Five minutes (more...
23
6,440
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
293
Totally off topic, but strange observation. I purchased a few cisco ethernet switches off of ebay some years ago. They are part of a home lab...
2,078
Good morning, Please excuse me if this is too off topic here, but it is a programmable controller of sort. I have an Omron ES100P temperature...
2,340
Which way is up and what's that strange looking bug? I was trying to login to micro_cr*p team_Shi* and it wouldn't let me because I exhibited...
2,703
