Omron ES100P, a bit off topic?
dalem
Sep 2005
NE Wisconsin
104
Good morning,
Please excuse me if this is too off topic here, but it is a programmable controller of sort.
I have an Omron ES100P temperature controller that is having some issues with the 4-20ma output and trying to by some time. It is on a batch burn off oven and has a number of profiles programmed in along with an external output relay board that takes care of some other needed outputs.
Questions is, has anyone know of or have any experiences with this controller and/or the ES/TOOLS configuration software (DOS).
Been looking for the software for a while now with no success, but what I want to do is get in and view, record or save parameters being used. I have sourced a used controller but without getting info out of this failing unit, I can't do much with the spare controller.
Any assistance or directions much appreciated and again, sorry if this is too off topic for this forum.
Dale
This goes way back!
I found a backup from 2005 that has ES Tools Windows version.
File size is about 3 mbytes.
PM your email address and I can send it to you.
Not sure what kind of support you will be able to get.
These were not the easiest controllers to program.
gtsuport
Thank you. PM on way.
Now to make a cable. Shouldn't be too hard. I do see some factory cables on ebay though.
BTW: More often than not, as is with many, I am my own support center. especially on older stuff like this where there is no mfg support.
Thank again.
Dale
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
132
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
100
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
136
