Weintek MT6050ip/MT8050ip always in calibration mode
noor_then
Jan 2020
Tangerang
hi all..
we have problem with HMI Weintek. HMI always show in calibration mode even after restart the unit.
is there anybody have experience with this case, please share:cool:
thanks
Yes do ensure all dip switches are off, it could be in cal mode. I have had a similar problem some time ago, although the switch seemed to be off it was actually making contact, I switched it on/off a few times & this cured the problem. I also had a similar experience on a different make, this turned out to be the touch screen, someone had given it a bit of a knock or used a sharp instrument that caused the particular area to be seen as a key press, it happened to be the area you hold while booting to calibrate the screen, however this is unlikely to be your problem as it requires a dip switch to set the mode.
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
228
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
591
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
385
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
953
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,383
