FX2N PLC Integration with 2 Weintek HMI.
sultanahmed
Jul 2013
home
63
Hello everyone,
I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a single Weintek HMI using the 4-wire RS-485 interface, everything works perfectly. However, when attempting to connect a second HMI in a multi-drop configuration on the same 4-wire RS-485 interface, both HMIs seem to malfunction. I've tried changing the HMI station numbers, but the issue persists.
FX2N PLC only has a single available port. I'm seeking advice on how to successfully connect two HMIs to the FX2N PLC. Any guidance or suggestions would be greatly appreciated.
Existing HMI is 8102ip. I know the feature of remote Hmi configuration.
My reservation for this is to lay ethernet cable which is not posible.
I already layed 485 cable for both hmi.
What protocol does the HMI use to communicate with the PLC? I suspect the problem lies with two masters (the HMIs) trying to communicate with a single slave (the PLC). What you are trying to do may not be possible with the protocol you're using.
Upon looking at this manual:
https://dl.mitsubishielectric.com/dl/fa/document/manual/plc_fx/jy992d69901/jy992d69901e.pdf
I come to the conclusion that the protocol does not support what you're trying to do. In Mitsubishi's terminology, the protocol supports 1:N connection where the "1" device is the HMI client and the "N" represents up to sixteen server PLCs communicating with a single client. You are trying to implement a 2:1 configuration which is two clients trying to communicate with a single server. The protocol does not appear to have any provision to arbitrate collisions between requests from the two clients.
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,077
Hi everyone, I am new here and this is my first post. I've just received my new PLC by post. It is a FX2N-20MT, a chinese clone of a Mitsubishi...
28
18,340
Hi there new user here. I have been assigned the task of upgrading the plc of a small machine. The machine is old & has a Mitsubishi FX2N-80MT...
2,871
what is the controlled power where does it come from and where does it go I know it is well on this system it seems to be the negative 24V but...
1,874
Our theater’s house curtain controller has a Mitsubishi Melsec FX2n PLC in it that was installed back in ’02. The back up battery failed and of...
1,714
