No Controlled power on the HMI FX2N PLC system
Greg7683
Jun 2018
Plainfield IN
355
what is the controlled power where does it come from and where does it go I know it is well on this system it seems to be the negative 24V but when I push the button nothing happens it just keeps saying no controlled power on the hmi I used to get it working by jumping a wire in the start button but doesn't work that way anymore I replaced the switch and still nothing.
Its an older Fuji HMI
Gives and error no controlled power and servo driver malfunction 1 and 2 the servos are fine but the control box don't seem to be getting that bit of -24 to kick everything into gear I have been running down the wires I just don't know where or what the controlled power should be going to to power everything up. Been working on it for two days.
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
224
All, We have a site that has multiple Altivar 66's that are being controlled by an old Square D Modbus+ network. One of the VFD's has failed...
381
Is there any issue with running a VFD-controlled 3-phase induction motor in torque control mode in the braking region continuously (back-driven by...
4,073
I've been presented with five PF525's with embedded ethernet ip. They need to be controlled by an Idec FC6A plc. I skimmed a PF525 manual when I...
1,262
My boss has come up with the idea of renting machines and charging on a per use / per hour basis, so I'm looking into it - just getting my feet...
3,994
