Hello all,
Did anyone have the similar experience of setting DH+ communication between a PLC 5 and a SLC 500?
I tried to set up DH+ communication between a PLC 5/60B and a PLC 5/04C. Each PLC could be individually
download, online, remote prog. remote run by RSLogix 5 or RSLogix 500. I set 1B port of PLC 5/60B as DH+,
57.6 KBaud, Node 2, Link ID 3, Diagnostic File 14, Global file 12 (copy from AB manual). SLC 5/04c, Chan. 1 DH+,
Baud 57.6K, Node 1, passthru Link ID 2; Ch0. DF1 full Dulex, passthru link ID 1. the rest is the default settings.
Also, SLC 5/04C bit S:34/5=1. The laptop connected ch0 of SLC 5/04C. Both 1B of PLC 5 and DH+ of SLC are solid green.
But in RSLinx, under DF1-1 driver are the laptop and SLC 5/04 icon, under SLC 5/04 icon is DH+ driver and another SLC 5/04(ch0) icon! It should be PLC 5, not another SLC.
What's wrong of my setting? The PLC 5 was in Rem Run mode. The SLC 5/04 was in Rem prog mode. Then I had com port conflict problem and couldn't put SLC in run mode. The programs only have the channel settings, no any other code.
Thanks,
Eric
Thanks,
Eric
