how to configure T-100 card in Simovert drive using drive monitor software.
sultanahmed
Jul 2013
home
63
Hi Experts,
i am working on Simovert Master drive in which CUVC and T-100 (technology card 6SE7090-0XXB7-0BB0) card is installed.
I have drives backup in my laptop, when i replace T-100 card from simovert drive and check drive it is not working where as when i use old T-100 card it is working on it,
when I research and found i have to configure T-100 card in simovis software,also found simovis software is obsolete now further more alternatively i have to use drive monitor latest version which is compatible with simovis software now i am using drive monitor v.5.05.01.
i search in drive monitor software unfortunately i did not find how to configure t-100 card it in drive monitor software.
what i got from drive monitor is warning which is attached.
1)do i require any packages to install???
2)and what is the procedure/method to replace T-100 card from drive.
3) how can i configure T-100 card while using drive monitor.
Please Experts help requiredto_Oo_O
thanks in advance.
what is in slot F undefined?
and you are saying that you can go online in drive monitor with the old t100 installed.
also what happened when you click on generate database.
I am not overly familiar with simovert drives but may be able to give you a few pointers
The T100 data has to be generated. I believe in your case you would click that button "Generate database".
When I created a new Drivemonitor file, there was a drop-down box to select the technology type. (DriveMonitor V5.5)
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
44
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
173
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
248
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
162
Hi all, the machine I am programming the Rockwell PLC for has about 100 parameters that need to be adjusted for every customer. I would like to...
20
2,014
