AS-i 31 vs 62 node
Who's valve?
You'd probably have to check their documentation to be for sure, I don't know if node 31 address of 20 is equivalent to 62 address of 20A. From a "bits and bytes" perspective, it might be but probably best to page through the manual. Or call their tech support.
"In order to retain full forward and backward compatibility, the size of the data frame exchanged between the network master (Scanners and Gateways) was not increased. Instead, one of the four output bits was used to select between the so-called A and B nodes. This enabled each of the 31 addresses to be used twice. The address space was increased to 1A to 31A plus 1B to 31B."
https://en.wikipedia.org/wiki/AS-Interface#Original_specification_(1994,_Version_2.04)
Seems that version 2.04 (31 nodes) are compatible with 2.11 (62 nodes) but maybe not later version 3.0?
As Paully said, check the documentation for your valve. And network master/gateway.
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
161
Looking to tery and send some tags from wincc to node red dont have a wincc connectivity license so can use opc. Any suggestions ?
77
Hello All, getting my feet wet currently with Node-red, curious if anyone has experience with the SMB share add-in(or whatever the terminology...
304
Well actually I'm a person and not a fan but either way. I'm an old in-my-60's PLC guy and I recently had a project which spec'ed for a...
1,223
Howdy Everyone, We have an old ternary drive from Wittenstein it is a TXBA046AAQ, i got the EDS file so i can add it to RSNETWORX for devicenet...
732
